Hub Two Arrived :)
cbcadmin
Hub Two Arrived :)
My Hub Two arrived today and gives me the chance to thank @Mav publicly for sussing the reason I resorted to Thumbsnap for attachments: I needed to request Desktop site. Wink
Not sure why mobile users wouldn’t need to attach files, but hey; it works. Smiley
Impressed with the length of the power cord! Smiley
Hub TwoHub Two
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
9 REPLIES 9
cbcadmin
Re: Hub Two Arrived :)
Can anyone confirm the power consumption of a Hub Two please? "Apparently it consumes 8.11 Watt hours (0.00811 kWh) of electrical energy for every hour" Anyone know how this compares to Vodafone's TH3000?
pjmarsh
Fixes: 24
The details of the HubTwo are all here.  No idea on other ISPs equipment.
cbcadmin
Thanks. The THG3000 is rated at 12v at 2.5 amps, which is 30 watts, so will use 0.72kWh per day.
cbcadmin
Hub Two would be 0.00811 kWh x 24 = 0.19464 Seems a *lot* less.
Fixes: 585
That's the max rating of the PSU. It wont actually consume that but information on actual cons seems pretty sparse...
cbcadmin
It’s all a minefield. I don’t think manufacturers want you to know what a product consumes. Sad
cbcadmin
Hub Two jumps to 18.80 W under load. so 0.01389 x 24 = 0.33336
Fixes: 585
When leccy was <10p/kwh it probably wasnt worth the effort to check what all these devices permanently on were using, now at >30p/kwh it is. If I'm away for a week or more I'll now turn everything apart from essential like fridge and freezer, off. From checking smart meter data , I reckon the non-essential (when not in the house) stuff amounts to about 50w, so 1kw/day!
cbcadmin
I am the same in turning off non-essential devices. I once couldn’t work out why I was consuming an extra 1kwh a day, until I found I’d left a light on in the garage! Smiley
it looks like the Hub Two is slightly less power hungry than the THG, but time will show.
