Hub One log limits
SteveA
Hub One log limits
All the logs on my Hub One are showing things like:
12:24:14, 07 Apr. (2049952.650000) CWMP: Initializing transaction for event code 2 PERIODIC
06:44:47, 07 Apr. (2029585.200000) CWMP: session closed due to error: Could not resolve host
06:44:47, 07 Apr. (2029585.150000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
06:44:46, 07 Apr. (2029585.140000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,2 PERIODIC,4 VALUE CHANGE'
12:24:13, 06 Apr. (1963552.650000) CWMP: Initializing transaction for event code 2 PERIODIC
06:44:45, 06 Apr. (1943184.870000) CWMP: session closed due to error: Could not resolve host
06:44:44, 06 Apr. <<<<<<<<<<<<<<<<<<<< Limit of tr069 log >>>>>>>>>>>>>>>>>>>>
06:44:44, 06 Apr. (1943184.000000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
06:44:44, 06 Apr. (1943183.990000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,2 PERIODIC,4 VALUE CHANGE'
12:24:14, 05 Apr. (1877153.650000) CWMP: Initializing transaction for event code 2 PERIODIC
Does this mean the logs are full? If so how can I clear them?
4 REPLIES 4
bobpullen
Fixes: 290
Re: Hub One log limits
I suspect some buffer is at it's limit, doubt it's anything to be concerned about though.
Interestingly you have tr069 events both before and after that log entry (anything prefixed CWMP is tr069-related).
I suspect the only way you can clear the logs is to factory reset the device. I can give it a go for you if you like though? (clearing the log, not factory resetting the device)
SteveA
It would be good to know if there is someway to clear the logs. I've not checked them in the past couple of days so I've no idea what is going on.
bobpullen
Fixes: 290
In fact, I should have spotted this before:
The unit has been 'ceased' therefore I'm no longer able to communicate with it. The only way to bring it back would involve a factory reset (which will purge the logs anyway).
SteveA
So what does that ceased mean?
I'd rather not do a factory reset.. I can't believe that is the only way to clear the logs...
But it does look like that message is rather misleading as the logs still seem to be working
12:24:14, 12 Apr. (2481949.650000) CWMP: Initializing transaction for event code 2 PERIODIC
06:44:51, 12 Apr. (2461586.820000) CWMP: session closed due to error: Could not resolve host
06:44:51, 12 Apr. (2461586.770000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
06:44:51, 12 Apr. (2461586.770000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,2 PERIODIC,4 VALUE CHANGE'
12:24:14, 11 Apr. (2395550.650000) CWMP: Initializing transaction for event code 2 PERIODIC
06:44:50, 11 Apr. (2375186.500000) CWMP: session closed due to error: Could not resolve host
So that just leaves what is meant by ceased
