Hub One Router - One device drops out
johnprimmer
All devices connect to existing Hub One Router, both Wired and Wifi, (2.4 & 5 ). New android (14) tablet connects and then goes into continous connecting- connected / no internet access notifications, does not stop. Tried android tablet on Mobile Hotspot and another wifi network where it logs in and is stable.
Currently at a loss.
Suggestions please
1 REPLY 1
SammyM
Fixes: 101
Re: Hub One Router - One device drops out
Hiya @johnprimmer,
That is rather puzzling !
Can you do forget the wifi net work on the device and reboot the router.
Can you then try to connect it again and PM us the serial number off the router. With this we can see if we can see the connection register on the router it's self.
 Sammy M - Sheffield Team
