Hub One LAN setup issues - switching from Sky ER115
- My Router
- Re: Hub One LAN setup issues - switching from Sky ...
- « Previous
- 1
- 2
- Next »
Re: Hub One LAN setup issues - switching from Sky ER115
09-12-2021 8:21 AM
requires elevation?
You need to run the command prompt as administrator, click on start, type cmd and you should see the option required.
I see there are a couple of troubleshooting tips in the user guide, I would have expected the 4 second reset to work.
Dan.
Message 16 of 16
(503 Views)
- « Previous
- 1
- 2
- Next »
- My Router
