Hub One Issues
nacra6
Hub One Issues
Hello,
I am new and hope my question was not answered already, I have looked and couldn't find a reply.
The Hub One modem/router supplied by PlusNet had a weak WiFi therefore I turned it off altogether and purchased a TP Link WiFi access point which solved the problem across my home.
Now (a year later) the Hub One is giving me further grief - there is no internet (to eliminate WiFi issues I checked using an ethernet cable to the back of the router), having logged into the router it is stated "connected" to the internet. I restarted it and reset it to factory defaults but nothing helps. I assume there is an internal fault.
Given that I already have an effective WiFi solution I dont need a wireless router, I also have a switch, all I need is a reliable ADSL modem. Any recommendations?
Many thanks!
10 REPLIES 10
Strat
Fixes: 565
Re: Hub One Issues
Moderators Note
This topic has been moved from Broadband to My Router.
Fixes: 147
Re: Hub One Issues
Hi @nacra6
What colour is the status light on the front?
When you login to the home page http://192.168.1.254 , under My Services do you see your broadband username or [email protected]?
Standalone ADSL/VDSL modems can be expensive.
Dan
Longliner
All Star
Fixes: 8
Re: Hub One Issues
@nacra6
Many on this forum have installed a BT HH6, direct replacement for the Plus One but far better performance and wifi. Quick look on ebay shows a few at £15 which is what I paid two years ago. Plenty of setup info on this forum.
nacra6
Re: Hub One Issues
@Longliner
Thank you so much! Will try to get my hands on one.
Thanks again.
nacra6
Re: Hub One Issues
Dan, the colour on the front of the hub is blue, status is connected, and my PlusNet username apepars.
adamwalker
Fixes: 223
Re: Hub One Issues
Hi there, it sounds like there might be a fault with the router. Could you try a factory reset for us as the next step please? https://www.plus.net/help/broadband/router-user-guides/#:~:text=Use%20a%20paper%20clip%2C%20pen,now%....
 Adam Walker
nacra6
Re: Hub One Issues
I have carried out a full factory reset but no change. I have now given up on PlusNet router and ordered an alternative.
adamwalker
Fixes: 223
Re: Hub One Issues
Thanks for the update, I hope the new one works out and do keep us posted. What did you decide to go for?
 Adam Walker
nacra6
Re: Hub One Issues
I purchased a new BT Smarthub 2. Fungers crossed.
nacra6
Re: Hub One Issues
A new BT Smart Hub 2 sourced and installed, all is well (for now). Good bye Hub One.
