Hub One Firmware Updates
FIXED- Subscribe to RSS Feed
- My Router
- Hub One Firmware Updates
Re: Hub One Firmware Updates
05-01-2018 8:14 PM
Thanks Bob, router reset and back online. So it's just a case of waiting for the update to fix krack now
Dave
05-01-2018 8:20 PM
05-01-2018 9:32 PM
05-01-2018 11:04 PM
I think we have it now
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 05/01/18
Dave
06-01-2018 11:32 AM
That's the one 👍
06-01-2018 12:27 PM
Back up router ready. Time to practice my poor soldering skills
19-01-2018 3:51 PM
@bobpullen Yes Bob the last digits are 449. If I do a factory reset will I be able to restore my config backup?
23-01-2018 1:09 PM
@bobpullen Hi Bob, new to the forums and also Plusnet. We have been a customer for 2 months or so now and the Plusnet Hub One has been on ever since.
We are stuck on firmware 4.7.5.1.83.8.217 and I notice that there is a new firmware available.
Please could you let me know what you require from me to send you so you can push the latest firmware to our router?
Any idea why some are stuck with last update: unknown?
23-01-2018 6:51 PM
@bobpullen Hi Bob, also new to the forums but have had Plusnet for about a year and router is still on 217 firmware.
Have tried a reset but no updates so far.
Ditto, how do I go about getting the update pushed to my Hub One?
Thanks.
29-01-2018 11:18 AM
@lcockell, @ChrisaLyd12 & @Boshay, if you're able to factory reset your routers by holding something in the pinhole at the back of the device for 10 seconds or so, then the latest firmware revision should be sent to you within a few days.
29-01-2018 11:20 AM
Hi Bob, thanks for your reply - can we restore the router's config once factory reset?
29-01-2018 11:21 AM
@bobpullen I reset mine last week and then restored my backup. Do I have to wait a few days for you to update before I can restore my backup after resetting?
29-01-2018 12:18 PM
You should be able to, but it might be worth making a separate note of any relevant settings/customisation in case you encounter any difficulties.
@lcockell, it's likely you'll need to factory reset again. You should be OK restoring config ahead of the update being pushed.
29-01-2018 12:21 PM
Thanks Bob, any idea why some of the Hub One's are not updating and a factory reset works within a few days?
We've only had ours for 2 months and its been on ever since, but never updated.
29-01-2018 3:03 PM
Most of the examples I've seen in this thread are the result of the device not being present in our hardware management database (or being present, but in a 'disabled' state). There are various causes for this, but the best way to rectify the situation, is for me to re-add your device and for you to factory reset.
