Hub One - 5GHz WiFi issue
Chet
Re: Hub One - 5GHz WiFi issue
@bobpullen  can you update my router firmware please? Currently:
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 13/03/19
I thank you
drummer4breeze
Hi @bobpullen  please could you push the firmware update to me too please. I'm currently on 4.7.5.1.83.8.263 and having issues with the 5ghz broadband dropping out
paul_edwin
@disgruntled wrote:
@bobpullen thanks. This seems such a common problem should the update be rolled out to all users?
Hopefully, according to this message, it is 🤞
Bright8
thank you @bobpullen
bobpullen
Fixes: 330
@itsdanhind @Willip10 @Chet & @drummer4breeze - all done. You'll need to power your routers off/back on to apply the update.
bernardli
@bobpullen
I'm on the 273 firmware but still getting the slowdown after 2 weeks - normal speed is 70Mbps and then after 2 weeks it drops down to 15-20Mbps. I normally just reset the router and then it rights itself for another 2 weeks. Is it worth updating the firmware to the very latest one? If you think so then please can you update, thanks in advance
Willip10
@bobpullen  Thnk You
bobpullen
Fixes: 330
@bernardli - the later build fixes that issue. I've just pushed it your way. You'll need to power the router off/back on at your side to apply it.
MagNeto
Hi Bob,
Just to let you know, I am on 289 (July 2020 flavour) and I have been seeing dropouts on both frequencies from time to time.  I am usually far from the router, so I cannot see if the line is OK; except except twice: once the router remained blue and the other it lost connection i.e. amber. Would you be able to have a look at my router's log, or point me toward where to look to see what the problem is?
philglenny
Hi @bobpullen  could you update my router firmware please?
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated Unknown
barty
Hi Bob, that is a long list of questions. I’m on my mobile using the data to access this forum so I may miss a few as I need to scroll up and down to type and read.
1. iPhone cannot connect and states password is incorrect. I had previously had poor reception on my TV, but this has repaired itself. I often watch tv via Google Chromecast. I also have a MacBook Air that I occasionally use, but so far no issues.
2. Blue light
3.split
4. Persistent. One device
5. No trigger just happened suddenly
6. No
7.iPhone 7plus
8. No
9. Google nest, iPhone, Google Chromecast & Samsung smart tv, MacBook Air and work desktop PC. Obviously not all at the same time, but all via wifi.
barty
Hi Bob, I disabled 5GHz and still no connection. After turning on and off and on and then extending the lease. I now have wifi connection on my phone but no internet connection. My hub still has a blue light. My tv has also lost internet connection, but has wifi connection.
ewar166
Hi Bob
I’m having wifi issues . My firmware is currently 4.7.5.1.83.8.263 . Can you please send the update . Many thanks
usmn
Having the same issues @bobpullen.
Please can I get the new firmware too. Thanks in advance.
Alex
Fixes: 13
Hi @bobpullen
Not sure if you're working today but one side effect of the update is my sisters wireless printer has stopped working. It happened about the same time as we've had the update. I'll may pop over there later today, so I'll have another look and post back on here if I can find out anything else, I thought I took down the current firmware version she is on but can't find it so I will certainly make a note of that of course.
