Hub One - 5GHz WiFi issue
FIXED- Subscribe to RSS Feed
- My Router
- Hub One - 5GHz WiFi issue
Re: Hub One - 5GHz WiFi issue
21-05-2021 1:20 PM
21-05-2021 4:05 PM - edited 21-05-2021 4:17 PM
21-05-2021 4:36 PM
@Scottonpc - that's been done for you. You'll need to restart the router at your side to apply the update.
21-05-2021 5:14 PM
Hi @bobpullen, please can I have the latest firmware update to my Hub One. Current firmware: 4.7.5.1.83.8.263 and 5GHz intermittently disconnects and prompts for a password. Thank you.
22-05-2021 5:03 PM
22-05-2021 5:15 PM
Hi i have been experiencing the same issues with the router and its wifi. started October last year, speed seems to slow down and then nothing responds then you find the wifi has disconnected then when it reconnects says the password is incorrect. We have firmware 4.7.5.1.83.8.263, would i be able to get the latest firmware?
22-05-2021 6:49 PM
So far, so good. Thank you!
22-05-2021 8:47 PM
Hi @bobpullen could I possibly have the update too as we’ve experienced WiFi issues too. Thanks
22-05-2021 11:25 PM
22-05-2021 11:37 PM
23-05-2021 9:43 AM - edited 23-05-2021 9:43 AM
@KRichardW @tim1909 & @Triumpht120 - I have just pushed an update to your respective routers. You'll need to power them off/back on again to apply it.
@goldenfibre we've hundreds on the latest build and I've not seen any similar reports. Keep an eye on it and let me know should it happen again.
FYI folks, I am going to be away from home from today for some R&R, and I'm not expecting to be online much. As such, it's unlikely I'll be able to respond to any firmware upgrade requests until my return after the bank holiday.
Appreciate everyone's patience in the meanwhile.
23-05-2021 9:57 AM
23-05-2021 10:02 AM
@Indy62 - you've just caught me in time ![]()
All done. You'll need to restart the router.
23-05-2021 10:03 AM
23-05-2021 11:41 PM
Thanks have rebooted router from ADMIN
I don't seem to be getting stalling where I have to switch bands to get things moving (i.e. browsing or media on WIFI)
though Washing Machine is still fiddly (having to put tablet into / out of aeroplane mode etc. to get a connection on same 2.4 band)
