Hub One - 5GHz WiFi issue
FIXED- Subscribe to RSS Feed
- My Router
- Hub One - 5GHz WiFi issue
Re: Hub One - 5GHz WiFi issue
10-04-2020 11:57 AM
So I got the BT home hub 6 and have had it up and running for the last two days and what do you know...ALL my wifi problems are magically fixed!
Really disappointed in plusnet.
10-04-2020 12:34 PM
Hi @bobpullen , we've had this issue going back about a year now. Could you push the firmware upgrade to us?
We had switched the 5GHz network off for months but I would really like to start using it now.
I've tried a few of the suggested workarounds and nothing helps for longer than a few days. I can turn 5GHz off and on again which brings it back to life, but again only for a few days.
To confirm, the issue seen is that on the 5GHz network only, devices are unable to authenticate suddenly after a certain amount of time. 2.4GHz network is completely unaffected
10-04-2020 12:36 PM
Another update from me, 5ghz drop out again today even with the .273 firmware. Restart of router fixed it.
10-04-2020 1:07 PM
2 weeks without a drop on any 5Ghz device now with the .273 firmware.
Crazy how some are still having issues with the new firmware.
10-04-2020 2:40 PM - edited 10-04-2020 2:40 PM
Hi admins,
As this appears to be quite a major issue that's affecting many users with the Hub One, would it be possible to have an update on progress for the fix, please? Is the official plan to resolve this with a software update, and if so what are the timescales to have it pushed out to all users? Can the firmware be updated by affected end users themselves if made available for download?
Alternatively, is this a hardware-specific issue that can be solved only with new routers, in which case when are these likely to be dispatched?
Any insight into the plan of action would be useful and appreciated, thanks. Even a 'we're working on it, we don't have any details to share yet but bear with us'-type message would be beneficial.
Cheers,
Andy.
10-04-2020 2:48 PM
There is something going on and fixing this issue, whatever the issue is if any, is not happening.
However in my case it has thrown up a couple of other gremlins which are being sorted.
I have been given a BT hub 6 which seems fine. Once I know my line is stable I will be looking at a new modem/router mesh system. Happy days.
10-04-2020 6:10 PM
@lucylucylucy Was it easy enough to set up? Have bought a BT router myself as i'm fed up of this situation
10-04-2020 8:10 PM
Hi admins,
Software of my Plusnet Hub One is 4.7.5.1.83.8.263 last updated on 13 March 2019. I understand this is old. Can you push latest updates please.
Thank you,
10-04-2020 11:36 PM
11-04-2020 9:58 AM - edited 11-04-2020 9:59 AM
This is totally unacceptable, Hub One is not fit for purpouse. Either the long standing firmware problem should be fixed or they should be replaced with something that works as advertised on both 2.4 and 5g without requiring frequent reboots.
It is also unacceptable that there has been no response from plusnet admins to what is clearly not a few isolated cases.
11-04-2020 10:14 AM
11-04-2020 11:39 AM
11-04-2020 12:37 PM
Is it possible to get a firmware update?
Thanks in advance.
11-04-2020 5:30 PM
I posted yesterday requesting for an update and so far no response yet. Come on Plusnet 😒
11-04-2020 5:38 PM
@Dunner31 It was super easy and only took about 20 minutes in total?! I followed the instructions here: https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
