Hub 6
JB3
Hub 6
Hi I have purchased a bt smart hub I would like to connect to my Plusnet account as my WiFi signal on the Plusnet hub is rubbish. I cannot get this to connect to my broadband it it says on the back it is a bit smart hub type b, could anyone help me with instructions to connect this please.
Regards Jason.
7 REPLIES 7
bobpullen
Fixes: 314
Re: Hub 6
Have a look here.
Fixes: 398
Re: Hub 6
Welcome to the forum.
The instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Most importantly don't plug the DSL cable in until the instructions tell you.
JB3
Re: Hub 6
Have looked at this, when I get to point 6 on advanced settings there is no edit username however I can click in the username and password boxes and change these to my Plusnet ones. There is no save button so as per instructions I then attach my dsl cable and click connect, in the top right it says connecting for a few seconds then disconnected it does this every time I click the connect button and also the hub 6 has turned solid orange colour.
LifeonMars
Seasoned Pro
Fixes: 12
Re: Hub 6
Take a look at my post 41 here.
Ensure that you have smart set up switched off.
especially the photos attached.
https://community.plus.net/t5/ADSL-Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
If BT Hub is Brand new (Unopened) then no reason to reset.
Plug DSL Cable in just before connecting after changing to your username@plusdsl.net
Fixes: 398
Re: Hub 6
Are you putting your username and password in correctly
Your username is that which you use to log into your Plusnet account followed by @plusdsl.net, for example joebloggs@plusdsl.net the password is also that which you use to log into your Plusnet account.
If this doesn't work can you possibly post a screen grab here of the page so we can see if the problem can be spotted.
Here's mine. It's a Business version so might be slightly different.hub.png:
JB3
Re: Hub 6
Hi thanks for all your help I have just tried it again after tea and it connected instantly! WiFi is brilliant compared to Plusnet own hub, works in all my rooms with no drop of speed!
Fixes: 1,480
Re: Hub 6
Moderators Note
This topic has been moved from Fibre to My Router
