Hub 2
- My Router
- Hub 2
Hub 2
24-03-2025 3:53 AM
My hub 2 router shows firmware version as unknown.
How can I ensure it is upto date?
Labels:
Message 1 of 3
(682 Views)
2 REPLIES 2
Re: Hub 2
24-03-2025 6:56 AM
How long have you had this Hub?
Message 2 of 3
(667 Views)
Re: Hub 2
24-03-2025 7:42 AM - edited 24-03-2025 7:44 AM
The current Hub two Firmware is 0.10.00.04201-PN
Assuming the Hub is this version, it is likely to be the only version the hub has had installed which explains no last update date
HTH
