Broadband Software question
nevica
Hello,
Is there any way within the broadband operating system to set the broadband wifi to turn between certain times (say between 12 midnight and 6 am).
Thanks,
Nevica
2 REPLIES 2
Fixes: 586
Re: Broadband Software question
@nevica from your other post I see you have a Plusnet Hub 2.
Its not possible to disable wifi itself on  a schedule BUT you can disable access to either all devices or groups of devices on a schedule.
See the help here https://www.plus.net/help/broadband/router-user-guides/hub-two/ and this thread https://community.plus.net/t5/My-Router/Hub2-Router-Scheduling/td-p/1971721 for some details
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
