Hub 2 unable to bridge to Deco E4
Jimmyj
Had been working perfectly fine with TP-Link deco E4 wired connection. Hub2 in bridge mode.
Have reset both hub 2 and deco but Deco is unable to reach internet and hub2 is not recognising the device
Have replaced the ethernet cable with one known to work
Any suggestions
2 REPLIES 2
Jimmyj
Re: Hub 2 unable to bridge to Deco E4
Correction S4 not e4
Fixes: 580
@Jimmyj not sure what you mean by that ?
However, first check that the Hub 2 is actually in bridge mode , its LED should be pink. Then you will need to set the DECO internet connection type as PPPoE and enter your Plusnet username & password. Username is your accountname followed by @plusdsl.net and password is the one used to login to the member centre.
