Deco X55 setup with Plus net FTTP
seasider_pow
Hi. Just had my FTTP installed. Works OK with Plus net router. Now trying to use Deco X55 mesh instead. Going through decon setup on my mobile and Deco can't connect to Internet & goes red. Yes, it's ethernet connected to the new box on the wall. Username & password were optional. Any suggestions on settings? I've disconnected the plusnet router.
8 REPLIES 8
Re: Deco X55 setup with Plus net FTTP
@seasider_pow
You configure the Deco X55 WAN to be PPPoE using your broadband user name and password, connect the Deco  WAN port directly to the ONT
HTH
seasider_pow
Thanks. Each Deco has 3 ethernet ports - can I use any of them as all look the same? Then use other 2 to connect devices?
seasider_pow
Tried again, and after assigning it a new network name and password the deco (which was saying it didn't have Internet connection, light goes red.
I would just connect one/the master Deco to the ONT and the try that.
It maybe possibly to configure them using a Web Browser on a pc of some sort.
Sorry I can't help anymore today as I'm about to go out
Fixes: 585
@seasider_pow that's not what you need to set. You need to set the internet connection type to PPPoE and for username it's your Plusnet account name followed by @plusdsl.net password is the one you use to login to the member centre
@seasider_pow
Having watched this video - YouTube : Deco X55 Setup Video
it seems relatively straight forward, if you assume that where it mentions 'modem' that instead you use the 'ONT'.
Then the only change would be at timestamp 1:56 where it has the "Connection Type", which you need to change from "Dynamic IP" to "PPPoE", then presumably it will prompt for your Plusnet account Username and Password,
where the Plusnet Username is probably in the format - '[email protected]'
- so presumably something like -  seasider@plusdsl.net
The video (in my previous post)  appears to indicate that you can use any of them as the device to connect to the ONT.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
