Hub 2 - need clarification on the hub's reported Data Usage
redulike
I have a Hub2. It's with FTTP but don't think that is important here.
I was just looking through the Hub settings   (ie Home - Advanced settings - Broadband ) and noticed what i thought was unexpectedly  high (at least to me!) upstream data usage compared to downstream :-
   Data usage: 33.2 GB Uploaded / 146.7 GB Downloaded
Can anyone confirm that the 33.2GB does indeed relate to data going out to the outside world, and not to any data between my local networked devices?
Cheers
Red
7 REPLIES 7
PhilipHeyes
Seasoned Champion
Fixes: 28
Re: Hub 2 - need clarification on the hub's reported Data Usage
I would say those are the figures for the data to / from the WAN i.e. the public internet.
Got some live streaming CCTVs or a family member with a Torrent server or even cloud backups.
markhawkin
Champion
Fixes: 22
Looking at my statistics, upload being 20% of download is where my Plusnet connection sits at the moment over a couple of weeks.
I would say the significant upstream traffic generator is working from home and (in particular) Microsoft Teams use.
AyToZed
Due to my WAN connection being restarted last night (BT or Plusnet doing something), I can report only a slightly less than 24 hour period.
Up - 21.9MB
Down - 278.2MB
Another thing you might want to look at
Home -> My Devices or Home - > advanced -> My devices
You should see Up and Down values for each device.
A restart of a WAN link won't clear these. (Disconnecting and removing the device or rebooting the Hub2 will)
In my case some examples
VoIP phone - 403MB up, 305MN down
PC - 5.1GB up, 67.9GB down
(managed) switch - 0B up, 0B down (I've not connected to the switch over IP since the last reboot of the Hub2).
Therefore I have to conclude that the figures from Home - Advanced settings - Broadband is network traffic leaving and entering the home (i.e. no local LAN traffic).
Ian06
Fixes: 6
Our usage over a week:
Upload  2.4GB      Download 42.4GB
We only do emails, internet browsing and radio/TV streaming.  Nobody Working From Home and No Gaming....
redulike
Thanks all for helping confirm all that data is from Hub to the outside world.
I'll check out what devices are responsible , and why, just in case it's affecting general wi-fi response times. What makes this more tricky is that some devices are used by two users, so it might be down to what they are individually doing/using.
I'm curious in case some 'apps', or OSs, are using my devices to distribute data around the country.
So that's all in this thread. Might need to open another thread if I discover anything interesting .
Cheers for now
Red
markhawkin
Champion
Fixes: 22
Unless you have any file sharing or similar software running I doubt you are being used as a source of traffic to others.
It’s possible that some virus or infection is generating traffic and it would be worth taking a look at computers using virus checking software ( I wouldn’t suspect phones) but I think what you are seeing is what is normal with the modern “cloud” world.
Ian06
Fixes: 6
@markhawkin wrote:  I think what you are seeing is what is normal with the modern “cloud” world.
Yes I would check what Windows is doing (if you use it - it keeps wanting to back up my PC to the microsoft cloud for me.)  Also my iPhone wants to back up stuff to the cloud as well.
I generally try to turn these off as I am not sure I want anyone (esp. Microsoft) keeping my data "safe" for me online.
