Hub 2 and Netgear Nighhawk R8000P compatiable
SCGH
Hi. I am about to change Full Fibre. Currently I use the Hub 1 (for my wired devices) and this is connected to a Netgear Nighhawk R8000P (tri-band, brilliant unit with a very strong signal that can easily handle all our wifi connections that the Hub 1 could not).
Will I still be able to connect the Nighthawk to the Plusnet Hub (in this case the Hub 2)? I have no idea about fibre compatibility.
2 REPLIES 2
Fixes: 585
Re: Hub 2 and Netgear Nighhawk R8000P compatiable
With Full fibre you don't need to use the Hub 2 at all. Just connect the WAN port of the 8000p to the ONT, then configure the Internet connection for PPPoE with your Plusnet username & password.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router
