Hub 2 and Netgear Nighhawk R8000P compatiable
- My Router
- Re: Hub 2 and Netgear Nighhawk R8000P compatiable
31-08-2023 1:55 AM - edited 31-08-2023 1:56 AM
Hi. I am about to change Full Fibre. Currently I use the Hub 1 (for my wired devices) and this is connected to a Netgear Nighhawk R8000P (tri-band, brilliant unit with a very strong signal that can easily handle all our wifi connections that the Hub 1 could not).
Will I still be able to connect the Nighthawk to the Plusnet Hub (in this case the Hub 2)? I have no idea about fibre compatibility.
Message 1 of 3
(1,105 Views)
2 REPLIES 2
31-08-2023 7:01 AM
With Full fibre you don't need to use the Hub 2 at all. Just connect the WAN port of the 8000p to the ONT, then configure the Internet connection for PPPoE with your Plusnet username & password.
31-08-2023 9:09 AM
Moderators Note
This topic has been moved from Full Fibre to My Router
Message 3 of 3
(1,063 Views)
- My Router
