Hub 2 and IOT devices
- My Router
- Re: Hub 2 and IOT devices
21-08-2024 9:42 AM - edited 21-08-2024 9:44 AM
Recently I upgraded from Hub 1 to Hub 2 and since then I’m having serious connectivity problems with IOT devices. In order to ensure my devices connect 100% of the time I have to change the 2.4 G WiFi to mode 2 and fully disable 5G WiFi. Affected devices are Shelly sensors/switches, BroadLink WiFi sockets, RaspberryPI 3b, and Timemaster WiFi spurs. With Hub 1 everything was fine without any tweaking! I’m also surprised that you can’t have different SSIDs for 2.4/5G channels. This is very much a backward step to me!
Labels:
Message 1 of 3
(1,178 Views)
2 REPLIES 2
21-08-2024 10:10 AM
Moderator's note:
Thread moved from Broadband to My Router
Message 2 of 3
(1,165 Views)
21-08-2024 10:53 AM
Routers supplied by ISP are basic, to get the average customer up and running. You could obtain your own advanced router and use it in place of the hub2.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others.
Message 3 of 3
(1,123 Views)
