Hub 1 on old firmware
TiptreeJam
I have occasionally glitches with my Hub 1 and just noticed it is still on firmware 4.7.5.1.83.8.263. Do I report this to Plusnet customer services or can I update it myself.
Tags (2)
6 REPLIES 6
Fixes: 480
Re: Hub 1 on old firmware
@TiptreeJam
You can’t update this yourself so you need to contact Plusnet, hopefully a member of the help team will come along and pick it up. It is not possible to update some early firmware so I would suggest that you ask for it to be replaced with a Hub 2.
TiptreeJam
Thanks for info. I did contact Plusnet via my online account but no response for 2 weeks and no response from them on here either. Probably time to look for a new provider Smiley
Fixes: 389
Have you tried calling them? (0330 123 9123)
willcutforth
Fixes: 113
@TiptreeJam I can give you a call and pop you through to the team if you want?
 Will Cutforth
TiptreeJam
Hi. Thanks for your reply. I got a response from customer services via Twitter(X) and they told me to hardware reset my hub on the back with a paperclip. I did that and it loaded in the latest hub software. I just need to update some of the settings and connected device descriptions to what I had before the hardware reset. Thanks again.
TiptreeJam
