Hub 1 lifespan?
- My Router
- Hub 1 lifespan?
Hub 1 lifespan?
26-01-2020 7:15 PM
Hi all. How long should the Hub 1 last for? From experience, it seems roughly between 12-18 months ((unless I keep receiving dud ones).
I normally ask for a new one everytime I renew my contract.
Thanks.
Thanks.
Message 1 of 4
(417 Views)
3 REPLIES 3
Re: Hub 1 lifespan?
26-01-2020 7:26 PM
How do you manage to brek them?
I don't remember ever having a router go faulty - mind you, I do prefer using my own - more control and better performance.
Message 2 of 4
(411 Views)
Re: Hub 1 lifespan?
26-01-2020 9:22 PM
For some reason, their performance seems to wane after a year or so. Drop-outs, disconnections, hissing noise coming from one of them etc...
Message 3 of 4
(379 Views)
Re: Hub 1 lifespan?
27-01-2020 1:38 PM
How long should a piece of electronic kit last? Much longer than some do. As an (ex) electronics engineer responsible for mission critical kit, if it failed potentially millions of people would have seen the result. Many failures are now caused by poorly designed kit working just in the edge or over the edge of the specs of the components they use. Then there is no safety margin. The kit I used or designed had a minimum 50% headroom. Just look at the spec of components which will have a mean time between failure rating and then ask yourself, why did it fail so soon?
Message 4 of 4
(326 Views)
