How to temporarily suspend Port Forwarding for a specific rule (i.e. Lock/Unlock)
JohnAtPheasant
I use the PlusNet Hub Two router Port Forwarding to link to a backend Tomcat Server and all works as expected.
The router I replaced this with (TP-Link) had an option to 'Lock | Unlock' a specific Port Forwarding rule. This was useful as could leave it in a Locked state except for when I wanted to access Tomcat as part of my development.
I can't seem to find a similar option for the PlusNet router, only to delete the rule and re-enter it each time. While not a lot of work, seems a bit clunky if there is a way to Lock | Unlock a rule.
Tags (1)
2 REPLIES 2
Re: How to temporarily suspend Port Forwarding for a specific rule (i.e. Lock/Unlock)
@JohnAtPheasant welcome to the community,
the option does not exist, might I suggest you change the target IP Address to one that is not used?
HTH
JohnAtPheasant
Hi Dan, thanks for the confirmation. I thought that it wasn't there as UI didn't seem to lend itself to that option. I keep Tomcat inactive anyway but nice to have the extra option of knowing that the port is closed when I don't actually need it. Will probably just keep deleting and adding it back in, just a few more keystrokes but as only need it active once a month or so, not too much extra effort.
