How to clear HubOne event logs
aks100
Is there a way I can clear the HubOne event log?
I have captured the logs all the way back to when my connection started.
2 REPLIES 2
Fixes: 480
Re: How to clear HubOne event logs
Try a factory reset by pushing a paperclip or similar in the reset hole. Hold the switch closed for at least 20 seconds.
Why would you want to keep them?
aks100
Thanks Baldrick1, I keep them just for reference to observe any differences of behaviour over time, which I have found useful on odd occasions.
I'll try to clear via reset button as you suggest.
