How to change Hub2 IP Address
BlueLagoon
Yesterday I had a Virgin Media Hub using IP address  192.168.0.1 hard wired to a TPlink Router that I use as an Access Point with all WiFi devices and a couple of PCs accessing each other and the Internet via the TPLink Router.    Today I have had a Plusnet Hub2 installed with OpenReach installing Fibre to the property. The problem that I have is the the Plusnet Hub2 is assigned an IP Address of 192.168.1.254. How can I change the Plusnet Hub 2 IP Address to 192.168.0.254 ?
Thank you
2 REPLIES 2
Re: How to change Hub2 IP Address
@BlueLagoon welcome to the community
Form the the Home page navigate to Advanced Settings >My network >IPv4 configuration
You can make the necessary changes there
HTH
BlueLagoon
Thank you Dan_the_Van
