How to access router from remote with static IP
PAN21
I have a static IP since quite some time. After changing the service to Fibre I got a new router and I cannot access it anymore from remote.
Do I have to add a port number to the IP address? If yes which one?
I look forward hearing from you.
Best regards,
Harald
2 REPLIES 2
Fixes: 585
Re: How to access router from remote with static IP
Im afraid its not possible to configure the Hub One for remote administration
Fixes: 1,495
Moderators Note
This topic has been moved from Fibre to My Router
