How do you configure secondary ip, static DHCP and static NAT on this silly box?
CiscoKid
 I was told this router had advanced configuration options. I want to connect a vpn, I need a static 1-to-1 nat to map the public to the vpn server tep. i also want to configure static dhcp bindings. And also how do I configure access control lists?
 It says advanced configuration but I can not configure anything.
Regards
CiscoKid
2 REPLIES 2
CiscoKid
Re: How do you configure secondary ip, static DHCP and static NAT on this silly box?
Also,
 Hoiw do I configure an IP route?
 Im in advanced configration settings but can not see any options
Fixes: 577
I'm afraid you're going to have to source your own router if you want that sort of functionality
