How do I set up a VPN on my Plusnet router
Saltyseas
I have subscribed to Nord VPN who inform me that I can put a VPN on my router to cover all my devices. I have checked with plusnet and yes I can use  VPN. If I go into advanced settings then I see VPN, I have switched this on. Now I dont know where I go from here, Can anyone help please.🤞
5 REPLIES 5
Re: How do I set up a VPN on my Plusnet router
@Saltyseas welcome to the community
Nord VPN has misinformed you, it NOT possible to setup a Plusnet Hub with a VPN client or server
Fixes: 480
Moderator's note:
Thread moved from Broadband to My Router
Mustrum
Fixes: 81
@Saltyseas    the Nord site has more info on which routers can be used and how to set it up.
https://nordvpn.com/blog/setup-vpn-router/
Saltyseas
Thank you
Saltyseas
Thank You...
