Changing SSID name 2.4GHZ and 5GHZ
DavidBevan
Is it possible (advisable) to change one of the SSID names on the HUB 1 either the 2.4GHZ or the 5GHZ so that they have different names. I have been experiencing problems with my Samsung phone being unable to connect to WiFi following a recent update.
One suggestion was that dual band routers using the same SSID name for both bands may be causing the problem.
Thanks for any advice
David Bevan
5 REPLIES 5
RPMozley
Seasoned Pro
Fixes: 18
Re: Changing SSID name 2.4GHZ and 5GHZ
Quick answer, yes.
Longer answer, there is no detrimental effect to splitting the SSID's and may help alleviate issues you've been having.
That's RPM to you!!
Mustrum
Fixes: 81
Yes. If you log into the router, add a 5 to the 5Ghz SSID and untick the synch with 5Ghz on the 2.4 section.
Apple devices in particular don't like it when both are the same name.
DavidBevan
Thanks for replying so quickly.
DavidBevan
Thank you both, I've followed your advice Mustrum and it seems to be working.
Thanks again
David Bevan
Mav
Fixes: 518
Moderator's note:
Moved to appropriate board.
Forum Moderator and Customer
