Help, please; Plusnet Hub Two causing a misery
rodneymf
Finally went to FTTP yesterday which necessitated moving from Hub One to Hub Two.  Since when my life has become a misery!  Whilst the router settings show my NAS, printer and android phone on the list of attached devices, I can't find my NAS using windows explorer so it won't connect to exchange files, I can't get my printer to talk to my computer and I can't sync my calendar on my computer with my mobile.  Can anybody help, please?
Rodney
3 REPLIES 3
Fixes: 388
Re: Help, please; Plusnet Hub Two causing a misery
@rodneymf In the case of your printer, that needs to be returned to factory settings and allowed to pick up the new Hubs credentials - search 'reset printer.
Sorry I can't help with the other issues, but, again,using your search engine of choice, you should be able to find the required help.
@rodneymf
You didn't mention which windows version you are using.
With windows 10/11 the PC will detect a new network and have likely changed the network to a 'Public Network'
Try changing to 'Private network' to see if that helps.
rodneymf
@Dan_the_Van
Thanks so much for this.  PC on Windows 11 and the situation appears to have been exactly as you suspected.  Changed to a private network and the printer popped out the document I had tried to print.  Other things appear to be working as well.  I can breath again.
Rodney
