Help needed to get my CCTV available via remote connection
hemingwayj
Hi
Since joining PlusNet a few months ago I have been unable to access my CCTV remotely.
I tried to enable port forwarding as below but not working - any help appreciated !
14 REPLIES 14
Re: Help needed to get my CCTV available via remote connection
@hemingwayj welcome to the community
Looking at the rules they do look correct assuming the correct ports have been used.
There was a Broadband Account Firewall at one time which is worth checking it is to Low or Off. The option may now be missing but it is worth checking to outrule this firewall
Login into the members centre https://www.plus.net/member-centre/broadband/firewall
or Navigate from Home >Broadband >Broadband Fire (lower right)
The Hub Two has an event log which is worth checking found >Home >Advanced settings >Technical log >Event log
If you select category "Firewall" this will filter out other messages.
When using a port scanner like https://www.yougetsignal.com/tools/open-ports/  test one of the port forward rule, you should see an incoming message from either 104.18.2.126 or 104.18.3.126 to the tested port.
The scanner uses your current public IP address.
EDIT: You are able to connect to the camera's locally? Which camera model and app are you using?
hemingwayj
Many thanks for the help so far!
I have checked the ports before and again today and they all still come back as closed.
I cant connect to my camera locally either.
I use ANNKE kit and their app
I could not get to the firewall settings via your link but did look on the hub itself.  it is set to default.
I noticed a Dmz zone so added my cctv to that to see if using the static ip helped but still unable to connect.
Do you have individual camaras to connect to or a NVR.
When you moved internet providers have you reset the ANNKE equipment to the new plusnet router IP address range?
If my link did not work would suggest your account does not have a account based firewall, which what I expected.
Are you using DDNS for your external connection?
Should be no need to use the DMZ.
Fixes: 480
Moderator's note:
Thread moved from Broadband to My Router
hemingwayj
Hi
Connection is via a DVR. I set this up on the new router connection after moving to PlusNet and my plus net router shows activity against it but I can’t connect to the IP or app via WiFi or 5g
Not using DDNS
Thanks for any further help
What is your broadband provision, Part Fibre (FTTC/SoGEA copper to property) Hub using DSL connection or Full Fibre Hub WAN port connected to an Openreach ONT?
There are only THREE LAN ports on a Hub Two the port next to the DC power socket being used as a WAN only connection.
Are you able to connect locally using a screen keyboard/mouse to the DVR (not via an IP Address) to check the configuration?
Some more detail on the cameras and DVR model would helpful.
hemingwayj
Hi
I am on full fibre with HubTwo.
Pictures of connections included.
Red one is from BT socket and the other goes out to my powerline adaptor which has a receiving power line next to my DVR this DVR connects via Ethernet cable from that.
I am able to get to my DVR setting as it’s linked to a TV
I will take some pics of that but there a tonne of settings so bare with me thanks
hemingwayj
Unable to add anymore pics 😳🥴😔
hemingwayj
Ted Ethernet from BT box goes into hub into the WAN port
Port 1 goes out to my powerline which is TP Link
Thankss
Fixes: 585
Probably just the network settings will be sufficient
hemingwayj
DHCP (IPV4):
IP address 192.168.1.64
NIC type self adaptive
Subnet mask 255.255.255.0
Default gateway 1.0.0.0
MTU Bytes 1500
Default Route LAN1
Auto obtain DNS yes
Enable DDNS no
HTTP Port internal and external is 80 and external ip 0.0.0.0 UPnP status Inactive
RTSP Port 554
server port 8000
HTTPS port 9010
NTP enabled NO
Hope this
Means something to someone to help
The default gateway should be that of the Hub, which unless you've changed it will be 192.168.1.254
Fixes: 585
but if its set for DHCP
DHCP (IPV4)
then why isnt it getting the gateway address ?
@hemingwayj is there any possibility of connecting the DVR directly to the Hub , just to eliminate the powerlines ?
hemingwayj
OMG so annoying as I even changed  the powerline in the first place …. Have tried another and it’s online !
THANK YOU !
Will try it remotely when get a chance too but it’s connected internally thanks !🤩
