Help in setting TP-Link Archer VR2800 up to Full Fibre 500
Flourgrader
Hello Guys.
I just tried to replace my HUB2
with my old
TP-Link Archer VR2800 Router
up to my Plusnet Full Fibre 500
It did not work!
I configure the setting
by using my laptop connected with ethernet cable
to the Archer VR2800
then added the setting below.
Then disconnected the archer
and pulled the ethernet cable out of the HUB2
and put it into the back of the archer VR2800
then rebooted the archer VR2800
and it would not connect
to plusnet.
Can anyone tell me what I am doing wrong plz ?
These are my settings I am using
Router set in Wireless Router Mode
Internet settings
VLAN Tag not enabled
Connection Type PPoE
User Name what i signed up with
password what i signed up with
VLAN ID: not enabled
connection mode Auto
Authentication Type Auto: also tried CHAP
IPv4 Enabled
Default Gateway pppo_1_d
IPv6 not enabled
Do not clone mac address on
LAN Settings
IP address 192.168.1.254
Sub Mask 255.255.255.0
12 REPLIES 12
RobPN
Fixes: 15
Re: Help in setting TP-Link Archer VR2800 up to Full Fibre 500
@Flourgrader
Did you enter your username in the correct format? i.e. "[email protected]" (without the "")
Edit: (I'm not familiar with your router, so can't help with anything other than the above)
Fixes: 146
@Flourgrader
Are you connecting the ONT to the LAN/WAN port of the VR2800?
What does the system log tell you? Advanced >System tools >System log
Flourgrader
Well RobPN
you must have been reading my mind.
that was exactly the problem
I had accidently hit a key a double time while typing giving the result of
"[email protected]"
Hence that was my problem.
Everything is working now
as I am typing to you.
If you see any problems in my listed settings don't hesitate to let me know
Thank you very much for  answering my help question.
Flourgrader
Thanks Dan for your help.
I am all sorted out now.
with a smile on my face.
It was my stupid mistake that screwed it up.
one too many dots in my user name.
my old eyes did not see the mistake.
TY
Fixes: 476
Moderator's note:
Thread moved from Full Fibre to My Router and appended topic 'Archer VR 2800 NOT up to the Job as a replacement' by the same OP
Flourgrader
TP-Link Archer VR2800 NOT up to the Job as a replacement for the HUB2 ?
Hello Guys,
I have full Fibre 500Mbps with upload of 72Mbps
I swapped my HUB2 for a TP-Link Archer VR2800
at first it appeared to be working just fine
I was getting speed test results from
Ookla of 518Mbps download & 71Mbps upload
but after an hour it had dropped to 178MBPS to
a Max of 200Mbps.
I left the Archer VR2800 connected to Plusnet
to see if it would improve and stabalize
the speed back to 500Mbps
It never did, I assume the archer VR2800
cannot cope with the speed despite
TP-Link say it can cope with these speeds.
I have now disconnected the Archer VR2800
from Plusnet and re attached the HUB2
and all speeds are back to normal 518 Mbps and
Uploads of 72Mbps.
If anyone has any views, or thought on this
please publish them. I would be interested in reading them.
I am thinking of buying a
TP-Link BE9300 Ultra-Fast 9214 Mbps 6-Stream Tri-Band Wi-Fi 7 Router, Five 2.5G Ports,
4K-QAM, EasyMesh-Compatible,
8K streaming, VR/AR
£299.99
I would be intrested to see what other people thought
about this as a repacement for the HUB2
Do you think it would be more than up for doing the job easly?
or
Do you think this would behave like the TP Link Archer VR2800?
TY
bobpullen
Fixes: 330
Re: TP-Link Archer VR2800 NOT up to the Job as a replacement for the HUB2 ?
Why are you wanting to swap your router out if you're already achieving the max speeds your subscribed product is capable of?
Flourgrader
Hi bobpullen
I like some of the options that are in the TP Link Archer VR2800
which i cannot find in the HUB2
Like binding the mac addresses and IP addresses together
Pooling of IP addresses seems better.
and other options i miss from the Archer.
I am curiouse to know why the archer appeared to work for the first hour or so then
started lagging?
I posted  so other people would have the benefit  of my experience
if they chose to swap there Hub2 out.
TY
bobpullen
Fixes: 330
started lagging?
How are you measuring speeds? If over Wi-Fi, there are a lot of variables to consider.
Allocating static IP's to mac addresses should be possible on the Hub Two, although I know there's been mixed feedback in those regards round these parts.
If you go for something higher end in the TP-Link range, then you need to consider the capability of the devices you have in your home. Purchasing a Wi-Fi 6/6E/7 router is no good if none of the devices in your home support the standard. Wi-Fi 6 devices are moderately common these days, 6E less so, and Wi-Fi 7 very sparse at the moment.
Flourgrader
@bobpullen,
I am trying to answer your question without
going off Piste,and making it a question of
My Router rather than Full Fibre topic!
All of my PCs are Ethernet connected.
All of them have 2.5 GB network cards in them.
I am in the slow process of upgrading all of the systems.
To answer your question bobpullen
I am measuring the Download speed from Plusnet>ONT>Router>PC>CAT8
cable is used throughout all of the System.
I connect to Ookla https://www.speedtest.net/
The Archer VR2800 has been swapped in and out with the HUB2
half a dozen times and fails to maintain the network speed.
I have come to the decission to stop trying to make it work
as I believe the CPU inside the Archer VR2800 is not capable of doing the Job.
    I do like to know the answer to puzzles, so if anyone does have
a good idea why the Archer VR2800 was not up to the job please
air your views and give your theory in why the speed starts off good
then reduce in speed drasticly after some time?
TY
bobpullen
Fixes: 330
The CPUs of the two devices are very similar. Both BCM and both 1GHz dual core from what I can establish. Do you have any of the QoS functions switched on when using the TP-Link? Could that be stressing the CPU?
Flourgrader
Thanks bobpullen for getting back to me on the Archer 2800
No the QoS functions are all turned off.
I have been through the router from top to bottom turning all the functions
off  that I don't need to lighten the load on the router.
Still I am only getting 170 to 190 Mbps. on the Archer 2800
Each time I go back to the Hub2 I get 510 to 518 Mbps.
I think I am flogging a dead horse with the Archer 2800.
I am looking at another router that i have just posted in the Forum on.
To get other people opinions on it?
as I am not an expert on router and networking...lol
TY
