HB-1 to HB2 ?
Gunnill
HB-1 to HB2 ?
After 5 years, I have the Hub-2.  Is there an easy way to install using the old settings etc.? Mainly to make the change as easy as possible.
Grateful for any feedback who made the change please?
Mike
2 REPLIES 2
Fixes: 118
Re: HB-1 to HB2 ?
@Gunnill
For WiFi you can log into the router management, go to the WiFi page and change the SSID and Password to your old settings. This sorts all your devices.
Note you cannot split the two bands.
Fixes: 585
Re: HB-1 to HB2 ?
Just change the wifi SSID and password to be the same as the Hub 1.
There's very little else that can be changed on the Hub 1 , so that should just about do it
