Full fibre WiFi problems
dmarks70
I’ve been with plusnet for years and never had a problem until I had full fibre installed. I am not always at the property and rely on the WiFi for Hive and to top up electricity. Since going to full fibre the hive connection keeps saying I am offline. Does anyone have any advice? I wish I had never’upgraded’ as it just seems worse. Thank you!
20 REPLIES 20
Fixes: 384
Re: Full fibre WiFi problems
@dmarks70 The technology change will not have any effect on your internal network - its influence ends at the ONT. Did you change Hubs at the time of switching to FF?
dmarks70
Yes. I got sent the new router.
Fixes: 384
Which one did you have previously? Although if the new one does connect...  How often do you lose connection?
Fixes: 479
Moderator's note:
Thread moved from Broadband to My Router
dmarks70
I just had the older version I think. They just sent me a new one when I had the new box fitted. It is offline more than it is online so multiple times a day. I wish I hadn’t bothered if I am honest as it now means driving for 4 hours as I need it to be reliable.
Fixes: 384
If you are at the Hubs location now, can you export the event log and attach it to a post, please? Someone may be able to spot the issue.
Does the Hive unit reconnect automatically?
PhilipHeyes
Champion
Fixes: 18
Was the new Router for FTTP installed in a different place in your home to the previous Router for FTTC ?
ExForce9
Seasoned Pro
Fixes: 5
@dmarks70
Try connecting up the old router to your FTTP, and see whether the problem disappears.
  • If the problem goes away, then you'll know that the new router's wifi isn't as good as the old model.
  • If the problem persists, then that tends to suggest that there is something wrong with the full fibre setup.
What speed is your full fibre supposed to be ?
dmarks70
Exactly the same place
dmarks70
I’m not there now but how do I do that and then can try when I am next there
Fixes: 384
The event log would still provide better clues to the problem - IMO.
Fixes: 384
If you are referring to my request for the event log, @dmarks70 , navigate to the page on your Hub as in the attached image, click the 'export button and attach it, via the 'paper clip', left and below the reply window.
ExForce9
Seasoned Pro
Fixes: 5
@dmarks70 wrote:
I’m not there now but how do I do that ...
@dmarks70
If you were referring to my post then -
unless you started a new Plusnet account at the same time as your FTTP upgrade, and kept your WiFi SSID the same,
your old router should still have your account and wifi settings saved in memory,
so you would just swap the cables from the new router to the equivalent sockets on the old
and it should just work.
@dmarks70
What maybe required here what the Hub two does not support is split WiFi band names, which was possible with the Hub One.
You can use a Hub One for Full Fibre; it's performance would struggle with any product over 145/30.
If you are mostly away from theis location I would suggest buying your own router which supports remote management, most third party routers allow for WiFi SSID band name splitting, or better still  IoT (Internet of Things) WiFi which can be used for your Hive system.
