Firmware update
hydrus
Firmware update
I've resurrected the Plusnet supplied router, as the replacement Draytek I used appears to be in the process of dying.
The firmware in the Plusnet router is probably quite old:
1. Product name:Plusnet Hub
3. Firmware version:Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version:Plusnet Hub OneI
Is there a method of updating the firmware, if indeed there is a newer version?
Thanks,
Mark
4 REPLIES 4
Fixes: 392
Re: Firmware update
@hydrus There is definitely a newer f/w, but your version is too old to update from.
hydrus
Re: Firmware update
@jab1 Thanks for the info. I suppose I should be glad it works at all!
Best,
Mark
markhawkin
Champion
Fixes: 22
Re: Firmware update
@hydrus
I would try a different PSU "brick" on the Draytek.
My Draytek says 12 - 15v and 2A so anything similar (with the + & - the right way round) is worth a try.
hydrus
Re: Firmware update
@markhawkin  Thanks for the suggestion. I'll check my stock of old transformers and see if there is something suitable.
Best,
Mark
