Disabling Hub Two hidden network
sampward
Hi, I've just installed a new hub two router. I need the option to turn wireless off completely but note when I turn off the 2.5 and Ghz networks in the settings there is still a hidden network pushing out a signal. How do I turn the wireless off completely?
Many thanks
10 REPLIES 10
Fixes: 587
Re: Disabling Hub Two hidden network
There should be a further option 'Disable all wireless' . This will disable everything including the hidden network
sampward
Thanks. I don't have that option though in wireless advanced settings.
I wonder if it could be that my firmware is an old version. It's this - v0.06.00.12134-PN
Thanks again.
Sam
Ian06
Fixes: 6
There was a thread on this last year:  here   and a firmware update was expected to allow the hidden network to be switched off.
@bobpullen was the firmware update ever rolled out?
Fixes: 392
@Ian06 It was - @sampward , for some reason, has old f/w.
sampward
Thanks both, really helpful. How do I get the updated firmward?
Fixes: 392
How long has this Hub been online? Have you ever replaced it with another for any reason - it looks as though it has fallen off the management platform.
sampward
It was sent to me a few months ago when the old router had an issue. But the old router starting working again so I didn't install the new one until I've started having issues with the old one again! Sorry if this has messed up the system!
Fixes: 587
Yes it was. The firmware version which disables wifi completely is v0.08.00.08297-PN
We are now on v0.10.....
bobpullen
Fixes: 331
@sampward - looks to me like a firmware update was pushed to you this morning. Try rebooting the hub.
sampward
That's great, just done that and I have the option to disable all wireless now. Thanks all for the help.
