Fibre broadband keeps dropping, router light goes orange
andyt1970
Re: Fibre broadband keeps dropping, router light goes orange
Just found the order receipt for this desktop PC and there is actually a built in PCI (?) wi-fi card inside, could this be interfering?
Just want to connect it to the router via a reliable ethernet connection......
andyt1970
Thank you so much, I/we could cry as you seem to be the only person acknowledging there is something not right.
Fixes: 378
If it  has a Wi-Fi card, try it with that, especially if the Hub is in the same room - if it isn't too good, you can always go back to Cat6.
The Wi-Fi card shouldn't interfere if you are connected by ethernet, but is there a way of checking whether it is in an active state - I'll have to go back to the Windows machine if you ask 'how'?'
andyt1970
I have the free "ProtonVPN" but only connect when needed and always disconnect.
andyt1970
The router is still downstairs for now, as advised by Plusnet and Openreach.
Fixes: 378
OK the Wi-Fi is disabled, so won't be having any effect.
Fixes: 378
As I said, where the Hub is won't affect the BT infrastructure which is at fault.
andyt1970
3.14pm another drop, now logged out of work for 15 minutes. Orange light on router, just gone blue again 😒
Fixes: 378
Anything in the logs, Andy - LAN or WAN?
andyt1970
andyt1970
15:15:35, 10 Dec. (58101.330000) WAN operating mode is VDSL
15:15:35, 10 Dec. (58101.330000) Last WAN operating mode was VDSL
15:15:34, 10 Dec. (58100.010000) PPP IPCP Receive Configuration ACK
15:15:34, 10 Dec. (58100.010000) PPP IPCP Send Configuration Request
15:15:34, 10 Dec. (58100.000000) PPP IPCP Receive Configuration NAK
15:15:34, 10 Dec. (58100.000000) PPP IPCP Send Configuration ACK
15:15:34, 10 Dec. (58099.990000) PPP IPCP Receive Configuration Request
15:15:34, 10 Dec. (58099.980000) PPP IPCP Send Configuration Request
15:15:33, 10 Dec. (58098.850000) PPPoE is up -​ Down Rate=75718Kbps, Up Rate=19999Kbps; SNR Margin Down=3.2dB, Up=7.6dB
15:15:33, 10 Dec. (58098.840000) CHAP authentication successful
15:15:33, 10 Dec. (58098.790000) CHAP Receive Challenge
15:15:33, 10 Dec. (58098.790000) Starting CHAP authentication with peer
15:15:33, 10 Dec. (58098.780000) PPP LCP Receive Configuration ACK
15:15:33, 10 Dec. (58098.780000) PPP LCP Send Configuration Request
15:15:33, 10 Dec. (58098.770000) PPP LCP Receive Configuration Reject
15:15:33, 10 Dec. (58098.770000) PPP LCP Send Configuration ACK
15:15:33, 10 Dec. (58098.770000) PPP LCP Receive Configuration Request
15:15:33, 10 Dec. (58098.770000) PPP LCP Send Configuration Request
15:14:43, 10 Dec. (58049.410000) PTM over DSL is up
15:14:09, 10 Dec. (58014.560000) PTM over DSL is down after 965 minutes uptime
15:14:09, 10 Dec. (58014.550000) PPPoE is down after 964 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
15:14:06, 10 Dec. (58011.770000) PPP LCP Send Termination Request [User request]
23:09:30, 09 Dec. ( 135.890000) WAN operating mode is VDSL
23:09:30, 09 Dec. ( 135.890000) Last WAN operating mode was VDSL
23:09:28, 09 Dec. ( 134.740000) PPP IPCP Receive Configuration ACK
23:09:28, 09 Dec. ( 134.740000) PPP IPCP Send Configuration Request
23:09:28, 09 Dec. ( 134.730000) PPP IPCP Receive Configuration NAK
23:09:28, 09 Dec. ( 134.730000) PPP IPCP Send Configuration ACK
23:09:28, 09 Dec. ( 134.730000) PPP IPCP Receive Configuration Request
23:09:28, 09 Dec. ( 134.720000) PPP IPCP Send Configuration Request
23:09:27, 09 Dec. ( 133.750000) PPPoE is up -​ Down Rate=76833Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=7.4dB
23:09:27, 09 Dec. ( 133.740000) CHAP authentication successful
23:09:27, 09 Dec. ( 133.690000) CHAP Receive Challenge
23:09:27, 09 Dec. ( 133.690000) Starting CHAP authentication with peer
23:09:27, 09 Dec. ( 133.690000) PPP LCP Receive Configuration ACK
23:09:27, 09 Dec. ( 133.680000) PPP LCP Send Configuration Request
23:09:27, 09 Dec. ( 133.680000) PPP LCP Receive Configuration Reject
23:09:27, 09 Dec. ( 133.680000) PPP LCP Send Configuration ACK
23:09:27, 09 Dec. ( 133.670000) PPP LCP Receive Configuration Request
23:09:27, 09 Dec. ( 133.670000) PPP LCP Send Configuration Request
23:08:38, 09 Dec. ( 84.640000) PTM over DSL is up
23:07:48, 09 Dec. ( 34.600000) WAN Auto-​sensing running.
00:00:33, 30 Aug. ( 34.040000) WAN Auto-​sensing running.
21:39:50, 09 Dec. (119549.070000) PTM over DSL is down after 264 minutes uptime
21:39:50, 09 Dec. (119549.070000) PPPoE is down after 264 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
21:39:47, 09 Dec. (119546.170000) PPP LCP Send Termination Request [User request]
17:15:49, 09 Dec. (103708.750000) WAN operating mode is VDSL
17:15:49, 09 Dec. (103708.750000) Last WAN operating mode was VDSL
17:15:48, 09 Dec. (103707.240000) PPP IPCP Receive Configuration ACK
17:15:48, 09 Dec. (103707.240000) PPP IPCP Send Configuration Request
17:15:48, 09 Dec. (103707.230000) PPP IPCP Receive Configuration NAK
17:15:48, 09 Dec. (103707.230000) PPP IPCP Send Configuration ACK
17:15:48, 09 Dec. (103707.220000) PPP IPCP Receive Configuration Request
17:15:48, 09 Dec. (103707.200000) PPP IPCP Send Configuration Request
17:15:46, 09 Dec. (103705.900000) PPPoE is up -​ Down Rate=78382Kbps, Up Rate=19999Kbps; SNR Margin Down=3.8dB, Up=7.9dB
17:15:46, 09 Dec. (103705.880000) CHAP authentication successful
17:15:46, 09 Dec. (103705.800000) CHAP Receive Challenge
17:15:46, 09 Dec. (103705.800000) Starting CHAP authentication with peer
17:15:46, 09 Dec. (103705.790000) PPP LCP Receive Configuration ACK
17:15:46, 09 Dec. (103705.790000) PPP LCP Send Configuration Request
17:15:46, 09 Dec. (103705.780000) PPP LCP Receive Configuration Reject
17:15:46, 09 Dec. (103705.760000) PPP LCP Send Configuration ACK
17:15:46, 09 Dec. (103705.750000) PPP LCP Receive Configuration Request
17:15:46, 09 Dec. (103705.750000) PPP LCP Send Configuration Request
17:14:56, 09 Dec. (103655.780000) PTM over DSL is up
17:14:21, 09 Dec. (103620.300000) PTM over DSL is down after 4 minutes uptime
17:14:21, 09 Dec. (103620.290000) PPPoE is down after 3 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
17:14:18, 09 Dec. (103617.160000) PPP LCP Send Termination Request [User request]
17:11:11, 09 Dec. (103430.750000) WAN operating mode is VDSL
17:11:11, 09 Dec. (103430.750000) Last WAN operating mode was VDSL
17:11:10, 09 Dec. (103429.270000) PPP IPCP Receive Configuration ACK
17:11:10, 09 Dec. (103429.260000) PPP IPCP Send Configuration Request
17:11:10, 09 Dec. (103429.250000) PPP IPCP Receive Configuration NAK
17:11:10, 09 Dec. (103429.250000) PPP IPCP Send Configuration ACK
17:11:10, 09 Dec. (103429.250000) PPP IPCP Receive Configuration Request
17:11:10, 09 Dec. (103429.230000) PPP IPCP Send Configuration Request
17:11:08, 09 Dec. (103427.940000) PPPoE is up -​ Down Rate=77365Kbps, Up Rate=19999Kbps; SNR Margin Down=3.1dB, Up=6.2dB
17:11:08, 09 Dec. (103427.920000) CHAP authentication successful
17:11:08, 09 Dec. (103427.880000) CHAP Receive Challenge
17:11:08, 09 Dec. (103427.870000) Starting CHAP authentication with peer
17:11:08, 09 Dec. (103427.870000) PPP LCP Receive Configuration ACK
17:11:08, 09 Dec. (103427.870000) PPP LCP Send Configuration Request
17:11:08, 09 Dec. (103427.860000) PPP LCP Receive Configuration Reject
17:11:08, 09 Dec. (103427.860000) PPP LCP Send Configuration ACK
17:11:08, 09 Dec. (103427.860000) PPP LCP Receive Configuration Request
17:11:08, 09 Dec. (103427.860000) PPP LCP Send Configuration Request
17:10:18, 09 Dec. (103377.640000) PTM over DSL is up
17:09:41, 09 Dec. (103340.920000) PTM over DSL is down after 0 minutes uptime
17:08:49, 09 Dec. (103288.200000) PTM over DSL is up
17:08:12, 09 Dec. (103251.550000) PTM over DSL is down after 0 minutes uptime
17:07:43, 09 Dec. (103222.250000) PTM over DSL is up
17:07:06, 09 Dec. (103185.890000) PTM over DSL is down after 16 minutes uptime
17:07:06, 09 Dec. (103185.890000) PPPoE is down after 15 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
17:07:03, 09 Dec. (103182.840000) PPP LCP Send Termination Request [User request]
16:51:49, 09 Dec. (102268.310000) WAN operating mode is VDSL
16:51:49, 09 Dec. (102268.310000) Last WAN operating mode was VDSL
16:51:47, 09 Dec. (102266.610000) PPP IPCP Receive Configuration ACK
16:51:47, 09 Dec. (102266.600000) PPP IPCP Send Configuration Request
16:51:47, 09 Dec. (102266.570000) PPP IPCP Receive Configuration NAK
16:51:47, 09 Dec. (102266.570000) PPP IPCP Send Configuration ACK
andyt1970
I only have WIRE LAN, going into kitchen now using laptop. My boy is home from school.
08:46:17, 10 Dec. (34742.590000) Wire Lan Port 1 down
08:38:44, 10 Dec. (34289.570000) Wire Lan Port 2 up
08:38:38, 10 Dec. (34283.570000) Wire Lan Port 2 down
08:38:14, 10 Dec. (34259.570000) Wire Lan Port 2 up
08:38:11, 10 Dec. (34256.570000) Wire Lan Port 2 down
08:38:05, 10 Dec. (34250.570000) Wire Lan Port 2 up
08:37:59, 10 Dec. (34244.570000) Wire Lan Port 2 down
08:37:56, 10 Dec. (34241.570000) Wire Lan Port 2 up
08:37:53, 10 Dec. (34238.570000) Wire Lan Port 2 down
08:37:44, 10 Dec. (34229.570000) Wire Lan Port 2 up
08:37:38, 10 Dec. (34223.570000) Wire Lan Port 2 down
08:37:35, 10 Dec. (34220.570000) Wire Lan Port 2 up
08:37:32, 10 Dec. (34217.570000) Wire Lan Port 2 down
08:34:11, 10 Dec. (34016.570000) Wire Lan Port 2 up
08:34:08, 10 Dec. (34013.570000) Wire Lan Port 2 down
08:34:02, 10 Dec. (34007.570000) Wire Lan Port 2 up
08:33:59, 10 Dec. (34004.570000) Wire Lan Port 2 down
08:33:56, 10 Dec. (34001.570000) Wire Lan Port 2 up
08:33:50, 10 Dec. (33995.570000) Wire Lan Port 2 down
08:33:29, 10 Dec. (33974.570000) Wire Lan Port 2 up
08:33:26, 10 Dec. (33971.560000) Wire Lan Port 2 down
08:33:02, 10 Dec. (33947.560000) Wire Lan Port 1 up
08:32:35, 10 Dec. (33920.560000) Wire Lan Port 2 up
08:32:32, 10 Dec. (33917.560000) Wire Lan Port 2 down
08:32:26, 10 Dec. (33911.560000) Wire Lan Port 2 up
08:32:23, 10 Dec. (33908.560000) Wire Lan Port 2 down
08:32:05, 10 Dec. (33890.560000) Wire Lan Port 1 down
08:32:02, 10 Dec. (33887.560000) Wire Lan Port 2 up
08:31:59, 10 Dec. (33884.560000) Wire Lan Port 2 down
08:31:41, 10 Dec. (33866.560000) Wire Lan Port 2 up
08:31:38, 10 Dec. (33863.560000) Wire Lan Port 2 down
08:31:17, 10 Dec. (33842.550000) Wire Lan Port 2 up
08:31:14, 10 Dec. (33839.550000) Wire Lan Port 2 down
08:31:11, 10 Dec. (33836.550000) Wire Lan Port 2 up
08:31:08, 10 Dec. (33833.550000) Wire Lan Port 2 down
08:31:02, 10 Dec. (33827.550000) Wire Lan Port 2 up
08:30:59, 10 Dec. (33824.550000) Wire Lan Port 2 down
08:30:56, 10 Dec. (33821.550000) Wire Lan Port 2 up
08:30:53, 10 Dec. (33818.550000) Wire Lan Port 2 down
08:30:26, 10 Dec. (33791.550000) Wire Lan Port 2 up
08:30:23, 10 Dec. (33788.550000) Wire Lan Port 2 down
08:30:11, 10 Dec. (33776.550000) Wire Lan Port 2 up
08:30:08, 10 Dec. (33773.550000) Wire Lan Port 2 down
08:29:47, 10 Dec. (33752.550000) Wire Lan Port 2 up
08:29:41, 10 Dec. (33746.550000) Wire Lan Port 2 down
08:29:35, 10 Dec. (33740.550000) Wire Lan Port 2 up
08:29:32, 10 Dec. (33737.550000) Wire Lan Port 2 down
08:29:23, 10 Dec. (33728.550000) Wire Lan Port 2 up
08:29:20, 10 Dec. (33725.550000) Wire Lan Port 2 down
08:28:47, 10 Dec. (33692.550000) Wire Lan Port 2 up
08:28:44, 10 Dec. (33689.550000) Wire Lan Port 2 down
08:28:41, 10 Dec. (33686.550000) Wire Lan Port 2 up
08:28:38, 10 Dec. (33683.550000) Wire Lan Port 2 down
08:28:17, 10 Dec. (33662.550000) Wire Lan Port 2 up
08:28:14, 10 Dec. (33659.550000) Wire Lan Port 2 down
08:28:08, 10 Dec. (33653.550000) Wire Lan Port 2 up
08:28:05, 10 Dec. (33650.550000) Wire Lan Port 2 down
08:28:02, 10 Dec. (33647.550000) Wire Lan Port 2 up
08:27:59, 10 Dec. (33644.550000) Wire Lan Port 2 down
08:27:47, 10 Dec. (33632.550000) Wire Lan Port 2 up
08:27:44, 10 Dec. (33629.550000) Wire Lan Port 2 down
08:27:38, 10 Dec. (33623.550000) Wire Lan Port 2 up
08:27:35, 10 Dec. (33620.550000) Wire Lan Port 2 down
08:27:32, 10 Dec. (33617.550000) Wire Lan Port 2 up
08:27:29, 10 Dec. (33614.550000) Wire Lan Port 2 down
08:27:26, 10 Dec. (33611.550000) Wire Lan Port 2 up
08:27:23, 10 Dec. (33608.550000) Wire Lan Port 2 down
08:27:20, 10 Dec. (33605.550000) Wire Lan Port 2 up
08:27:17, 10 Dec. (33602.550000) Wire Lan Port 2 down
08:27:11, 10 Dec. (33596.550000) Wire Lan Port 2 up
08:27:05, 10 Dec. (33590.550000) Wire Lan Port 2 down
08:26:59, 10 Dec. (33584.550000) Wire Lan Port 2 up
08:26:56, 10 Dec. (33581.550000) Wire Lan Port 2 down
08:26:11, 10 Dec. (33536.550000) Wire Lan Port 2 up
08:26:08, 10 Dec. (33533.550000) Wire Lan Port 2 down
08:25:11, 10 Dec. (33476.550000) Wire Lan Port 2 up
08:25:08, 10 Dec. (33473.550000) Wire Lan Port 2 down
08:24:59, 10 Dec. (33464.550000) Wire Lan Port 2 up
08:24:56, 10 Dec. (33461.550000) Wire Lan Port 2 down
08:24:08, 10 Dec. (33413.550000) Wire Lan Port 2 up
08:24:05, 10 Dec. (33410.550000) Wire Lan Port 2 down
08:23:53, 10 Dec. (33398.550000) Wire Lan Port 2 up
08:23:50, 10 Dec. (33395.550000) Wire Lan Port 2 down
08:23:41, 10 Dec. (33386.550000) Wire Lan Port 2 up
08:23:38, 10 Dec. (33383.550000) Wire Lan Port 2 down
08:23:26, 10 Dec. (33371.550000) Wire Lan Port 2 up
08:23:23, 10 Dec. (33368.550000) Wire Lan Port 2 down
08:23:14, 10 Dec. (33359.550000) Wire Lan Port 2 up
08:23:11, 10 Dec. (33356.550000) Wire Lan Port 2 down
08:23:05, 10 Dec. (33350.550000) Wire Lan Port 2 up
08:23:02, 10 Dec. (33347.550000) Wire Lan Port 2 down
08:22:59, 10 Dec. (33344.550000) Wire Lan Port 2 up
08:22:56, 10 Dec. (33341.550000) Wire Lan Port 2 down
08:22:35, 10 Dec. (33320.550000) Wire Lan Port 2 up
08:22:26, 10 Dec. (33311.550000) Wire Lan Port 2 down
08:21:44, 10 Dec. (33269.550000) Wire Lan Port 2 up
08:21:41, 10 Dec. (33266.550000) Wire Lan Port 2 down
08:21:23, 10 Dec. (33248.550000) Wire Lan Port 2 up
08:21:20, 10 Dec. (33245.550000) Wire Lan Port 2 down
08:20:05, 10 Dec. (33170.550000) Wire Lan Port 2 up
Fixes: 146
@andyt1970
not sure what John is looking for with LAN, WAN shows the dropped connection, can you capture from "ALL" in event logs for around 15:14:06, 10 Dec, this will give an overall look at the event.
Did the light just go Orange or did the b light come one as well?
Dan
andyt1970
Hope this helps? I didn't notice if the b light came on, sorry.
[EDIT: Removed anything that looks like an IP address]
15:17:34, 10 Dec. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [ ]:58176-​>[ ]:443 on ppp3)
15:17:13, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:52062-​>[  ]:443 on ppp3)
15:16:56, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:33259-​>[  ]:443 on ppp3)
15:16:34, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:46783-​>[  ]:8080 on ppp3)
15:16:14, 10 Dec. (58139.800000) CWMP: session closed due to error: Timeout
15:15:51, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:50039-​>[  ]:443 on ppp3)
15:15:44, 10 Dec. (58109.770000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
15:15:38, 10 Dec. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [  ]:49976-​>[  ]:443 on ppp3)
15:15:37, 10 Dec. (58103.290000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:15:37, 10 Dec. (58103.280000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:14:42, 10 Dec. (58047.610000) CWMP: session closed due to error: Could not resolve host
15:14:42, 10 Dec. (58047.600000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:14:42, 10 Dec. (58047.590000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:14:11, 10 Dec. (58017.320000) CWMP: session closed due to error: Could not resolve host
15:14:11, 10 Dec. (58017.290000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:14:11, 10 Dec. (58017.280000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:14:11, 10 Dec. (58017.010000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
15:09:43, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:9090-​>[  ]:22 on ppp3)
15:09:28, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:12653-​>[  ]:8080 on ppp3)
15:07:43, 10 Dec. IN: BLOCK [16] Remote administration (TCP [  ]:9090-​> [  ]:22 on ppp3)
15:00:01, 10 Dec. ath00: STA a0:d0:dc:f2:da:5d IEEE 802.11: Client disassociated
Fixes: 378
@Dan_the_Van Sorry, the LAN request was an aberration, due to something I was involved with on my local forum, sorry. 😉
@andyt1970 That last report proves my point - you are loosing PPP connection, as previously, without you doing anything to cause it - ignore that 'user request' tripe in the log above. It is something upstream of your Hub - in the BT/OR network which is borked and needs further investigation.
