FTTC to FTTP Upgrade - TP-Link Deco X55
imranad
I currently have FTTC (with my Hub2 Router using DSL on my phone line) and will be upgrading to FTTP with OTN being fitted on Friday.
The mesh network I use is TP-Link Deco X55 which connects by ethernet into my Hub2 with wifi disabled.
Once the OTN is fitted can I get rid of the the Hub2 and connect TP-Link Deco X55 directly into the OTN ?
Are here any settings or credentials I would need to add on its setting is this possible ?
1 REPLY 1
Fixes: 585
Re: FTTC to FTTP Upgrade - TP-Link Deco X55
Its actually an ONT (Optical Network Termination) but , yes, you need to change the X55 WAN connection to PPPoE and enter your Plusnet credentials. Username is <youraccountname>@plusdsl.net and password is the one you use to access the member centre.
