Ethernet details needed
Prmiaj
We have just put in a cat 6 cable from port 3 on the router to the port in our TV. My TV needs to be set up to recognise it as its not doing it automatically.
Can anyone help me?
Where do I find all the details it needs
IP address
Netmask
Gateway ID
DNS server 1 and 2
Thanks for any help you can give me!
6 REPLIES 6
mystreet1
Seasoned Pro
Fixes: 7
Re: Ethernet details needed
It might be that you need to change the settings from manual to automatically.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Prmiaj
It doesn't find it automatically that's why I'm in need of the info 😊
Fixes: 479
Moderator's note:
Thread moved from Full Fibre to My Router
Mav
Fixes: 518
If you give the manufacturer/model it may help someone to assist you.
Forum Moderator and Customer
Fixes: 583
@Prmiaj if the TV is set to get an IP automatically and it doesnt, then you almost certainly have a fault
have you tried
1) unplugging and reconnecting the cable to the TV ( make sure its fully inserted )
2) a different cable
3) a different port on the router ( if its a Plusnet Hub 2 then NOT the red port 4 )
If none of those work, then if you have a Plusnet router and have not changed it from the defaults then
IP address try 192.168.1.1 ( assuming you have no other devices set with static IPs )
Netmask 255.255.255.0
Gateway ID 192.168.1.254
DNS server 1 and 2 192.168.1.254
If those work, then I would suggest there is a fault with the TV as it should get all that information automatically
Prmiaj
Thank you very much. I did a hard reset on TV and reconnected all cables. All done now. 🙂
