EE Home Hub on Plusnet Fibre Line
metalligator
Hi All,
Just posting as I searched for this before trying but could't find an answer.
I am currently using an EE Smart Hub (I think) which I'm told is based on the BT smart hub (Home hub 6) successfully on my plusnet fibre connection.
All I did was put in my login details and save them, no fancy config/hacking.
Just putting this here in case anyone else is curious.
Tags (5)
10 REPLIES 10
Fixes: 1,495
Re: EE Home Hub on Plusnet Fibre Line
Moderators Note
This topic has been moved from Fibre to My Router
metalligator
The speed steadily increased a few MB every two days over the initial 14 days which was nice and capped out after about 10 days.
Trying to make sense of the speeds though as the router states:
Downstream sync speed:
70.83Mbps
Upstream sync speed:
18.09Mbps
But speed tests never get above
65.5 down
17.1 up
which is 92.47% and 94.52% of the routers stated.
I read around and saw 88.2% and 96% but just wondering if there is something amiss?
The speed tests are done over wireless but using the same router for virgin got speeds of 108MBps so guessing it isn't the wireless but maybe the wireless to modem link limiting it?
Also in my account says:
our broadband service
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 52 - 72Mbps
  • Estimated Upload Range: 15 - 18Mbps
  • Minimum Guaranteed Speed: 46.3Mbps
  • Current Line Speed (Download): 68.2Mbps
Which is different again
metalligator
FYI an update on this, this setup worked fine for everything apart from my wifes laptop would repeatedly drop out of teams meetings, swapped it for the standard plusnet one which fixed the issue but now getting 5ghz wireless issues
adam945
Fixes: 113
Thanks for reaching out @metalligator
You can find further support on addressing the 5GHz wireless issues here
 Adam
 Plusnet Help Team - Leeds
metalligator
Hi @adam945
I posted in this forum yesterday asking for the updated firmware but haven't heard anything yet.
Many thanks
adam945
Fixes: 113
Thanks @metalligator
You'll find that a member of our products team - bobpullen frequently pushes updates through to users posting on that thread, hang fire for a couple of days and this should be picked up. I'm unable to manually push updates through from my end I'm afraid..
 Adam
trevman
Hi, I can confirm this also worked for me.
Username: [email protected]
Password: yourPlusnetPassword
No other settings required. However, keep in mind that you might not be able to receive future firmware updates for the EE router. My last one was dated December 2020. In fairness to Plusnet, I have not tried their router, but I am familiar with the BT branded model of the router. The wifi coverage with that in my house was poor.
Tags (1)
Frankie72
I have tried to save my username and password to the ee brightbox 2 router but it tells me to enter a valid domain. If I enter the details without saving it tries to connect but boots me back to the settings page. Any help would be very appreciated.
RealAleMadrid
Fixes: 68
@Frankie72  EE routers are locked to EE usernames so cannot be used on a Plusnet connection. Get a BT Home hub 6 instead that will work on Plusnet and is miles better than the Plusnet hub1.
Mustrum
Fixes: 81
@RealAleMadrid  Not quite true if you read the whole thread - but the older Brightbox routers do have limitations.
The newre Smart Router and Hub are based on the equivalent BT versions, and so can be used on PN.
