Dreytek Vigor 2766
leighcocker
Dreytek Vigor 2766
Is it possible to use a Dreytek Vigor 2766 with my fibre connection and if so are the support team able to advice me of what settings I need to enter into the Dreytek to connect to my service.
Regards
Leigh
5 REPLIES 5
Fixes: 480
Moved:
Re: Dreytek Vigor 2766
Fixes: 480
@leighcocker
From my reading you can. The settings are here. https://www.plus.net/help/broadband/broadband-connection-settings/
Plusnet may not help with configuration but there are knowledgeable fellow members of this forum who will help.
Fixes: 586
@leighcocker  it should work just fine.
Set WAN1 to VDSL , PPPoE ( see pages 11 onwards of the QSG )
Where it needs username , use <youraccountname>@plusdsl.net and password is the one you use to access the Plusnet portal (member centre). Set the IP Assignment to Dynamic. That's it for any PlusNet specific settings.
leighcocker
Thanks all, Wil give it a go and hopefully can get connected
leighcocker
All sorted after a quick call for support for a password reset, thanks guys.
