Does the router from 2017 (2704N?) have 5Ghz?
dannyzee4
Hi
The Plusnet 2704N router. I'm looking at the advanced settings and only see channel 1 to 13. I guess it doesn't do 5Ghz, but if it does, where is the option?
3 REPLIES 3
Fixes: 383
Re: Does the router from 2017 (2704N?) have 5Ghz?
It is 2.4Ghz only
dannyzee4
I see. Thanks.
Longliner
All Star
Fixes: 8
Like myself, the 2704 is getting long in the tooth ... suggest you ask support for a Hub Two, or find a BT HH6 on the auction sites at £15 to £30. You'll see a vast improvement, plenty of setup info on this forum.
Mike
