Do I need a new router?
racepaint
I've just upgraded from Unlimited Fibre to Unlimited Fibre Extra.
The upgrade process says I needed to add a new router for this product.
I currently have a Netgear Orbi router with satellites into a BT Openreach modem.
Will Unlimited Fibre Extra not work with my current Openreach modem?
Do I NEED to use this additional Plusnet Hub Two router in some sort of modem only mode?
1 REPLY 1
Fixes: 480
Re: Do I need a new router?
@racepaint  Welcome to the Coimmunity forums.
Whilst a Plusnet hub is useful if you have a problem your current set up will work fine on Fibre Extra.
Moderator's Note
This topic has been moved from Tech Help to My Router
