Disabling SIP ALG Hub Two
stevec042
Hi guys,
Does anyone know how to disable SIP ALG? As I'm unable to make phone calls working from home.
I have a Hub Two
Cheers in advance
Steve
1 REPLY 1
bobpullen
Fixes: 331
Re: Disabling SIP ALG Hub Two
Log into the router GUI at http://192.168.1.254 and navigate to Advanced Settings > Firewall > Configuration.
From memory though, I think it's likely disabled by default.
