Deco M5
tulip1
Deco M5
Hi I am currently with Virgin broadband and use the Deco M5 mesh with the router in modem mode. I am looking to move to Plusnet full fibre and still wanted to use the Decos. I have read several posts that say I would need to connect the main Deco directly into the ONT box and not use  the hub. Is that correct ? Or would i use the hub in bridge mode ?
If anyone has set up Plusnet full fibre and the deco  M5 could you explain the set up on the app, apparently I've read you need to choose VLAN and  enter your plusnet ID and password,
Thanks very much
4 REPLIES 4
Fixes: 586
Re: Deco M5
@tulip1
That's correct.
Close, but not quite!. There is no VLAN ID required with Full Fibre. The guide on the website is for FTTC and hasnt been updated to include FTTP settings.
Im afraid i cant answer specifically regarding the M5 and its app but I have set up a number of different third party routers with PlusNet FTTP. Currently Im using a TPlink ER605 on my own FF 900 connection.
Basically you need to configure the WAN connection on the DECO for PPPoE with your plusnet username & password. VLAN disabled.
HTH
tulip1
Re: Deco M5
@MisterW Thanks very much for your reply , what you said made much more sense, especially the PPPOE connection, I can see that on the app, I think I saw the VLAN thing on the deco forum. I feel a lot more confident now, even though I have,not signed up with Plusnet yet. Once again many thanks
Fixes: 1,495
Re: Deco M5
Moderators Note
This topic has been moved from Broadband to My Router
Fixes: 586
Re: Deco M5
@tulip1 no problem. Shout up if you need more help. Not only are there some very knowledgeable customers on here, there are some very experienced Plusnet staff who monitor the forums.
