Connecting my hub 1 to my hub 2 to extend my wirless network
- My Router
- Re: Connecting my hub 1 to my hub 2 to extend my w...
10-03-2024 6:53 PM
Hi im new to the forum and after a bit of help.
A few years ago I connected 2 slave hub1's to a master hub1via lan cables to extend my wireless network through the house n down to the end of the garden using the instructions I found on this forum. I've just got a new hub 2 with our new contract and replaced the master hub1 with this but now my slaves will not connect and are looking to see if anybody can help me with this. Thanks.
Labels:
Message 1 of 2
(402 Views)
1 REPLY 1
Re: Connecting my hub 1 to my hub 2 to extend my wirless network
10-03-2024 10:52 PM
It should work, presumably you are using LAN sockets, not the WAN one?
The instructions are here, if necessary factory reset them and set the access points up again from scratch.
Message 2 of 2
(356 Views)
- My Router
