Changing SSID
Fixes: 53
Changing SSID
With the PlusNet Hub One can you change the SSID while connected via WiFi or do you need to be on a wired connection?
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 60
Re: Changing SSID
I've never had a problem changing a router's SSID via WiFi before, obviously the connection will drop but you simply scan for the new network name and reconnect.
Fixes: 1,603
Re: Changing SSID
What Browni said. Smiley
Fixes: 53
Re: Changing SSID
@Gandalf @Browni
Thanks for the info.
Would have tested things myself today but OpenReach failed to show up to do my FTTP connection. While I use a wired connection my neighbour uses WiFi (and will need to change things if OpenReach show up tomorrow!!!).
Waiting to hear what happened to my appointment.
