hub one manual
whackojacko1
hub one manual
For all those out there who are trying to find a manual for the hub one router is is available here:- http://setuprouter.com/router/plusnet/plusnet-hub-one/manual-2097.pdf
forget this post, I just checked my download and it's the standard setup guide
3 REPLIES 3
mikelahey
Fixes: 12
Re: hub one manual
 The router in that link is a Plusnet Hub Zero aka Sagemcom F@st 2704n not the hub one as per the post title
HarryB
Fixes: 256
Re: hub one manual
User guides for our Hub One, 2704n(Hub Zero) and Technicolor TG582n can be found here: https://www.plus.net/help/broadband/router-user-guides/
I hope this helps.
 Harry Beesley
Pete11
Seasoned Pro
Fixes: 4
Re: hub one manual
@HarryB
That's a nice set of guides, but there is no option to print or download them. If a person uses wi-fi instead of wired and can't connect to the net for some reason, then without a guide for the router the user is left high and dry.
Is there downloadable guide available?
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
