Changing Password Plusnet Hub 2
gnome_43
Re: Changing Password Plusnet Hub 2
OK prints attached
bobpullen
Fixes: 331
Just to be clear, does this happen regardless of the password you are trying to use? i.e. if you try changing it to some other random collection of 11 characters, do you have any more success?
gnome_43
No, I have tried that and have also tried a long one that is green
bill888
Champion
Fixes: 40
Have you tried using a different web browser to change the password?
gnome_43
Thanks, but yes I have (see earlier)
bill888
Champion
Fixes: 40
fwiw, have you tried using a totally different device, such as web browser on smartphone or tablet?
gnome_43
Well done - thanks very much, that worked immediately.
SammyM
Fixes: 101
Can you please PM me the serial number of the router you currently have plugged in @gnome_43 so that I can replicate the issue.
 Sammy M - Sheffield Team
gnome_43
Since curing the problem I have reverted to the new router you sent to me. This was because I could not get a stable internet connection. Now all ok with new router.
Old faulty router s/n +108417+2134014947
adam945
Fixes: 113
Ah fair enough @gnome_43, thanks for letting us know, and I'm glad to hear that using your initial router has sorted the problem. If you need any further support at all, please feel free to get in touch.
 Adam
 Plusnet Help Team - Leeds
