Capabilities of PN Hub - New FTTP Customer
germarsh
Re: Capabilities of PN Hub - New FTTP Customer
Now Christmas is done and the family have cleared off, I can get back to this. (Quite pleased I am too!)
I am attempting to mindmap the various use cases and factors for the transfer to fibre. Probably due to my "obsession" with this - and the fact that we have ended up with a complex home network - my long-suffering wife has set up the Plusnet account herself and organised the engineer. I think it prudent I don't get involved!
More web searches have turned up naff all on the functionality of the PN Hub 2 but I assume that I can change the IP address pool / range of its DHCP server and the IP address of the router itself.
The LTE modem on the roof is currently the DHCP server and I have set up a specific pool for that. However, some of the MikroTik functionality allows me to allocate a static IP address for any of the device allocated an address from the pool. Very handy for Home Assistant and the like. My experience with the usual domestic routers leads me to believe that I will not be able to do this for the Hub 2 so I need to sort out addresses which are not part of the DHCP pool.
As the fairly noddy MikroTik hardware is only capable of 100M ethernet, I need to remove that kit from the high-speed pathways. (The more I think about this, the more I believe that January 5th will be an interesting installation day for the engineer as well as me!)
My initial thoughts were to still allow one of the MikroTik devices (the actual wireless router in the lounge) to do the DHCP serving as that will keep all my "pseudo-static" addresses. As that would be on a 100 Mbps link, I could not use that as a part of the high-speed network requirements - which I am going to try to do with hardwire if I can. (I seem to recall that I tried that with the TV via the ethernet connection for the Deco P9 mesh but it turned out that the wireless i/f was faster!)
I once tried to hide a Cat5e along the wall in the lounge directly from the MK router to the TV but my wife spotted it immediately. Never even got to test the Netflix speed!
Thinking even more about this, I reckon the engineer has picked up a rather complex job here. I assume, though, that his responsibilty ends with just allowing one of our devices to speak via the fibre.
The only high-speed links so far are:
  1. TV - for Netflix etc (but even BBC iPlayer must be getting more bandwidth thirsty these days);
  2. Jellyfin on the Ubuntu laptop;
  3. The newly established pseudo NAS, also on the laptop.
At least the Ubuntu laptop can handle Gigabit ethernet.
I apologise for the verbosity but any advice would be gratefully received as ever!
(I seem to have got confused with the Youtube videos. Does the most recent installations not require a box on the outside of the property?)
Thank you - and Blwyddyn Newydd Dda (Happy New Year).
Gerald.
Example
Depending on how much you know about subnetting may give an answer regarding devices with static IP addresses in the above network (there are some devices with static addresses).
What I have found is that when it comes to DHCP the Hub2 assigns IP addresses to a device and it is an extremely sticky IP address in the local network within the DHCP pool. The only method I've found to "unstick" that stickyness is to redo the subnetting.
germarsh
Thank you, Grumble. Was there supposed to be some diagram with "Example"? I just get a pale yellow triangle symbol.
@germarsh
The Hub Two DHCP server is not the best, you can not manually assign an IP Address to a specific device MAC address, you have to attempt to change the IP Address allocated to the devices MAC address.
But as previously noted, once a device gets an IP Address it is sticky (unlikely to change).
Do not expect much from the Openreach engineer or their valued partner on the 5th Jan, all they will be interested in is the install of the ONT at hopefully a location of your choice and see it working on a router.
You should now be able to view the image.
germarsh
That functionality I can work with. I think that the subnet mask would only allow 32 addresses be allocated by DHCP.
Actually, the format of the pages looks very similar to my old PN hubs.
Here are the leases this morning. The devices with "D" in the second column are dynamic whereas the others are static. The manually configured devices, including some Shelly sensors, aren't listed as they are not in the DHCP range.
@germarsh
By default the Hub two network is 192.168.1.0/24 (class C).The default DHCP pool address is 192.168.1.64 to 192.168.1.253
with the Hub Two IP address being 192.168.1.254. You can use your preferred network ranges, but avoid 10.x.x.x ranges.
For me I use a TP-Link router as it's more configurable with a remote powerline fed WAP
EDIT: images have to approved before being public.
Fixes: 580
@germarsh
That will work providing the Mikrotik can support DHCP option 3 (Default gateway) . Since you will not be using the Microtik as the primary router, when handing out DHCP leases it will need to supply the IP of the primary router (the Hub 2?) as the gateway. That's done by specifying the gateway IP using DHCP option 3.
If you're still thinking about a replacement for the Mikrotik, this https://www.amazon.co.uk/Cudy-WR3000S-Ethernet-Antennas-Wireguard/dp/B0CYT3Q54S/ref=asc_df_B0CYT3Q54... is currently a bit of a bargain. It can easily be reflashed to official Openwrt using a Cudy intermediate image and then applying the genuine Openwrt firmware. Openwrt will give you all the facilities you are used to with the Microtik and with your tech knowledge shouldnt be too difficult to pick up quickly.
With H/W Offloading enabled the WR3000S should be able to easily cope with a 900Mb FF connection, although you wont be able to use QoS
germarsh
After another interesting discussion with my other half, I am under instruction to simplify the lot! I think it is that I am getting on a bit and she does not fancy diagnosing any hassle herself. As a result, we will just replace the MikroTik router with the PN one (just arrived, by the way) and disconnect a few hardwired links - including to the Swann cameras (as she now prefers the more modern IP ones). I have just logged on to the existing PN routers and I note one announces itself as Plusnet Hub One whilst the other is much simpler. The strange thing is that, even though I must have changed the router's IP address in the past, I can't find that option for the life of me! The Board Version of the Hub One is "Plusnet Hub One" whilst the other is "F@ST2704N".
I had better check the ethernet speeds of the older router as I was expecting to use that to link to the office kit. It is in an IP65 enclosure some distance up under decking - and it is rather fresh out there today!
Looking at the "static" ip addresses, perhaps I have over complicated matters...
Address Device Comments
3 MikroTik Modem and Router
4 EE Router Hub in Office
5 MicroTik Router
6 Scan PC WiFi
8 HP Printer In office
9 Plusnet Router North Shed
10 Plusnet Router Enclosure under decking
13 TalkTalk Router Not used
17 Scan PC Ethernet
22 VMS Virtual Machine (Domain: vms1.pc; Hostname: vms1)
45 Swann Cameras Gate
61 LG TV Lounge
64 Samsung TV Basement
65 Ubuntu Laptop Home Assistant etc
70 Edimax camera
76 HP Printer In office
101 Shelly EM1 Grid and Total House Consumption
103 Shelly ht1 First freezer
105 Shelly ht2 Second freezer
106 Shelly EM2 Basement and Main House Consumption
107 Shelly PM Mini Mains monitor
111 Technicolor Router Spare
112 TP-Link Router Office
113 BT Homehub 3 Office
114 Sky Hub Near gate
120 GSHP Rpi
121 Deco Master Now part of 192.168.0 network
122 IeGeek Camera North Shed (Inside)
126 Grandstream VoIP Controller
132 Yeskamo Goat Cam Battery operated – intermittent
137 Tp-Link Smart Plug Computer etc.
144 Tp-Link Smart Bulb Porch
146 Tp-Link Smart Bulb Porch
153 Raspberry Pi Webscanner in office
158 Yeskamo Chicken Cam (Not seen for 374 days!)
196 GUOAN S300 Camera Track (Outside North Shed)
221 MikroTik hAP Lite (WDS) Spare (Was in lounge)
223 Canon ip8750 Printer Office
250 BME680 Rpi Bedroom
Fixes: 580
That's a Hub Zero, it only has 10/100 Ethernet ports
germarsh
Thank you, MisterW - I found out some info on them from the forums. Old Sagecom I think. How the hell did I manage to change its IP addresses though has confused me.
I will need to replace that one with the Hub One in the sheep shed as that definitely has Gigabit ethernet. The sheep and pigs don't need a fast link for their web browsing!
Champnet
Fixes: 21
@germarsh  Wrote : "I once tried to hide a Cat5e along the wall in the lounge directly from the MK router to the TV but my wife spotted it immediately."
Have a look at flat ethernet cables. They'll run under carpets, doors etc. Being flexibe they're also ideal as patch cables.
germarsh
Whilst sussing out which cables are going where on the existing router, I noticed that the cable to the Deco P9 is flat and very small. I never knew they existed as my dear wife set up the mesh system.
There again, I set up a "temporary" ethernet link to the sheds when we were lambing about 7 years ago - not really an external Cat5 cable - and it is still working. It should be secured to a catenary but it is cable-tied to an armoured cable coming from PV panels. The only trouble I have had is with water getting in the so-called weather-proof connectors.
(I made my own ethernet tester where I soldered each twisted pair together in a cable and stuck a connector on the end. Then I created a cable with a standard plug except separated the cables and stuck them in a terminal block. Easy to test the resistance on each pair.  A couple of months ago I bought a much better version for not much money from Lidl. LED's check each pair.)
I have just configured the new hub in an attempt to minimise the configuration needed for it to be assimilated into the overly complex network.
Here it is 22:00 on New Year's Eve - perhaps she is correct and I am a bit obsessive!
(At least the damn router allows me to tweak the IP address and other items. I still haven't a clue how I managed to set it on the Hub Zero. In any case, why would any company call a device version Zero - suggests that it is not quite ready!)
My thoughts on 'sticky' IPs on the Hub2.
Probably down to the design/implementation of the firewalling features.
@germarsh
This is maybe what you are looking for Turning a Hub Zero into an Access Point details changing the IP Address.
germarsh
Ah yes - thank you for the reminder. That is how I did it.
Bit of a git it being hidden.
