Broadband username issue
MJL86
Hi
I have the same issue that many seem to have with regards to the username being [email protected], I have followed the instructions to change it to my details but every time it connect it reverts back to the setup username?!? Any advice?
9 REPLIES 9
Fixes: 392
Re: Broadband username issue
@MJL86 Is this a new connection (to Plusnet) and have you been advised that it is 'live'?
MJL86
Hi yes I am new to plusnet and reccived a ready to go email this morning
Fixes: 392
OK. I don't know which method you used to set your username, but be aware it can take up to 23.59 of your 'live' date for PN's system to 'get  all it's ducks in a row'. Try doing a factory reset on the Hub - press a paper clip or similar into the reset hole on the rear of the Hub, keep it closed until the light goes green, and then wait 5 minutes or so for it to complete the reset.
MJL86
Will try that thanks for your help
Fixes: 392
Let us know if it works.
HPsauce
Aspiring Champion
Fixes: 5
If it's a Plusnet-supplied hub you don't need to change anything, it's set up automagically.
If you do want to change it you probably have to "disconnect" first, you can't change that field while authenticated and connected. And remember to save it too!
Fixes: 392
@HPsauce The OP is a new customer - I suspect the PN systems haven't all lined up properly yet.
MJL86
All working well now. Thank you for your assistance
Fixes: 392
Glad to help, @MJL86 👍
