Boosters for dead zones
JulieD42
We’ve always had dead zones around the house, in 3 rooms. It’s really annoying. With BT they gave us the black discs which did help, We move to PN tomorrow and they don’t offer a guarantee around the house. My husband works from home so I need reliable boosters. Can anyone recommend one?
Thank you
1 REPLY 1
bobpullen
Fixes: 330
Re: Boosters for dead zones
How many discs were you using with BT in addition to the main hub/router?
If you want to stick with BT kit, then you could do worse than pick up some refurbished Whole Home Wi-Fi discs e.g. here.
Note, with Whole Home Wi-Fi, you would typically connect one disc to the Plusnet hub via etherent cable, situate a second/third disc remotely somewhere in your house, and then disable the Wi-Fi on the Plusnet hub i.e. it wouldn't work like the BT kit did where the main hub acts as one of the access points.
